Hp g6000 screen
The screen keeps flickering
Posted by Teresa Allan on
walter_yrle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 62 Answers
Please explain the events that lead up to your screen flickering ... in detail, from the time you turn the laptop on. Does the splash screen flicker?
Posted on Jan 04, 2014
Screen started to flicker when tilted, then the screen went very very dim,can only just see it. Whats causing it?
Hope this helps:
http://www.laptoprepair101.com/laptop/2009/05/04/how-test-lcd-screen-inverter-in-laptop/
Good luck
Oct 16, 2010 | HP Compaq Presario F500 F700 and G6000...
Hiya, my g6000 hp laptop will start up but there's nothing on the screen i have tried removing battery and adapter and pressing the power button for 30 secs and still nothing do you think its the...
http://h30434.www3.hp.com/t5/Hardware/Hp-G6000-Startup-Problems/td-p/91754/page/4
Seems this is a common problem to this model which the folks in the above HP forum are having. It seems to be a problem related to the Nvidia display adapters soldered connections to the motherboard
The poster smileygecko appears to have a solution but once you read it, you'll see its not for the faint-hearted.
I'm currently fixing the same problem for a friend and if I make any progress I'll let you know.
Otherwise if you're lucky enough to have any warranty left, take advantage of it!!
Sep 20, 2010 | Computers & Internet
My hp g6000 wont boot not even the bios menu comes up or the hp start screen
I have a g5000 laptop with the same problem. After a long research and testing the problem was that the motherboard and graphics card are dead and no replacement is cost worthy. Sorry to tell you but unless you can find someone to replace your nvidia card you cant do much.Hope that helped!
Mar 22, 2010 | HP Compaq Presario F500 F700 and G6000...
I have a hp g6000 power coes on but screen is
1. If you have it plugged to a power adapter it could be that the AC adapter is not charging the battery.
2. Try removing the battery with the AC adapter plug in and see if the PC will. if so then you may need a new battery.
3. You will need to get new AC adapter and battery frome the manufacturer or authorized dealer. Third party device are not recommended because they usually are not up to specifications.
I hope this helps.
Mar 16, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop, screen completely green. top and bottom taskbars are black/ red flickering.
Seem like your video is going bad on the motherboard or your LCD screen. This is how you can determine which is going bad:
- Connect a monitor to the output and toggle Fn+F4 about 2-3 times or until you see video on both screens.
--If you have that same picture on the monitor then its the internal video....new motherboard needed.
--If you don't have that problem on the monitor then its with your LCD screen and it will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | HP Pavilion dv6000z Notebook
Hi my ho nx9005 laptop screen keeps flickering
you have a problem with your flat it is a cable connecting the monitor to the notebook itself and may be damaged or not fixed in it's place
Oct 26, 2009 | HP Computers & Internet
Computers & Internet Logo
83 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
