Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
F3 code showing on Rangemaster Fridge Freezer
Posted by irene higgins on
1 Related Answer
Anonymous
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
Fridge not working
  • Are you getting power to the unit
  • do you see the light and fan working
  • do you hear the compressor running
  • how old is this unit.
Mar 03, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
Rangemaster fridge freezer not freezing temp 0.2 what should it be
could be condensation from a bad door seal? might also check the tempeture control thermostat
Feb 14, 2015 | Rangemaster RSXS663CRC Cream 500 l Fridge...
Temperature on freezer -3 not -18 as it should be
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 07, 2010 | Freezers
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Jan 17, 2010 | Refrigerators
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 27, 2009 | Refrigerators
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
john h
Paul Carew
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
