Question about 2004 Mustang Factory Wiring Diagrams
Need a diagram for 1989 suzuki 115 hp lower unit why i can not get out of reverse after replacing water pump impeller
Posted by rickeymckay9 on
Larry
    Sergeant:
  • 288 Answers
How to replace water pump on a evenrude/Suzuki 1999 50 hp 4 stroke
need to drop the lower unit(prop and all) to acess the chamber for the impeller.. give the impeller a small coating of grease so its not dry when starting up..
Oct 14, 2014 | Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
How to replace water pump on a 1985 90 hp mariner outboard motor
mcdevito75 Here, If I;m not mistaken the water pump is in the lower houseing, a big job, let the marina take care of it as the water pump should be Changed only if it doesn"t pump at all.
Jun 16, 2010 | 2004 Mercury Mariner
Water pump impeller change
There is another bolt up under the zinc plate on the cavitation plate.
Jun 04, 2010 | RTO Oar Sockets
Maytag dishwashwer problem
hi try this In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Sep 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
2004 Mustang Factory Wiring Diagrams Logo
146 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
