DeLonghi DCM485 Coffee Maker Logo
Question about DeLonghi DCM485 Coffee Maker
Not brewing Machine has suddenly stopped brewing although power looks normal and we have cleaned machine and reset the 4 bars indicating it needs to be decalcified. We may have waited to long but we can't decaldify if it won't run water through the basket. Do you know why this machine would suddenly stop brewing? It is less than a year old!
Posted by imnlytnd on
  • imnlytnd Sep 13, 2007
    No - if you push the button twice it should brew immediately. It just sits there. Any other ideas?
  • imnlytnd Sep 16, 2007
    Thank you! I will call Delonghi and see if I can find a service center. Dang machine - it is less than a year old and it was $129. Starbucks shouldn't be selling such crummy machines...we would never recommend this one.
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
It sounds like the pump inside is bad, from either a clog or fuse perhaps.the pump sends the water thru so thats the likley problem.
Posted on Sep 15, 2007
2helpful
I'm unable to push the brew unit all the way in. This started when the brew unit was not properly inserted when the machine was turned on causing it to jam. I found the instructions that said remove a...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
2helpful
The brew unit still won't fit back into the machine. I have clarified the make of the machine as I think you were describing a different machine in the last instructions. I do believe it could be a matter...
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
3helpful
I was cleaning the grinder and brew cup. When i went to put the brew cup back in place i accidently pushed the PUSH button. Now i cant get it back in the machine. The gears to the brew cup seam to be off...
Hi
Motor stuck in brew postion wont reset even with the brew group out
Hi
Leave the brew unit out but put everything else back in and then turn the machine on. the brew drive should reset to where it should be so you can put the brew unit back in, but make sure that the brew unit is ready to install.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the "Push", and twist it clockwise until it stops and the 2 marks are lined up. If you don't have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the "Push" lever until you hear a click and you are now ready to reinsert the brew group in to the machine.
1helpful
Dispenser out of alignment
HiTo return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press"button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
11helpful
2answers
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Machine does not dispense milk properly
Hi
There is a pin in the cappucinator the needs to be turned slowly to create the venturi action to make it work. If you have lost the pin it won't work.
1helpful
Brew Group will not reset
Hi Neil,
Try to put the dregsbox and driptray on place, close the door and turn on the machine.
When the machine stop again, open the door and put the brewing unit on place.
Best regards
/Mirran
2answers
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
Saeco stopped working during process
jammed brew unit, possibly also damaged gears.
Do not keep turning the unit on at this point, cuz it can damage it even further.
Has to be sent out for service, be sure to tell them to check gear system and mention jammed brew drive.
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Sean Wright
Sean Wright
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
