Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
A
Anonymous Posted on Sep 07, 2013
Squeal on phone - Vtech 5.8GHz Cordless Phone with Digital Answering System
Alan Harris
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 22, 2013
Alan Harris
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
53
Points
Nothing worked for me... UNTIL eureka, I just turned down the handset volume. Apparently, lower volume results in decreased feedback, Seems simple now.
Non-Belt engine squeal
It may be you harmonic balancer moved and rubbing on your timing cover or do you have a manual or auto transmittion
Squealing Tires?
Is it a tire squeal or brake squeal?If it is brake squeal put high temp synthetic brake lube grease behind the brake pads to reduce/remove the brake squeal.This allows the pads to sit on a bed of grease and will not vibrate at the frequency which produces the squeal.
2002 Mercury Cougar Squeal
Just for testing, a few seconds, will the vehicle start and run w/o the belt? Have a helper work the throttle, is the sound gone? If problem not the belt, check the belt driven accessory. Sometimes you can use a long metal rod of some kind, with belt on, one end of the rod touches accessory housing, the other end goes on that bone behind your ear, helps to magnify the sound. I guess you could use a mechanics stethoscope to do the same thing. Have helper work the throttle while you listen to each. Don't get tool or anything caught in belt. This is a serpentine belt, I haven't looked?
Maybe an accessory trying to freeze up or bad bearing? I can't think of anything else at the moment?
When i turn on my laptop theyre is a constant squeal noise and the fan starts turning immediately but i have stopped the fan from turning and the squeal continues so it cant be this.
To my recent experience the keyboard had to be replaced. It had something spilled on it unbeknown to the owner, making it squeal. I ordered a replacement, installed it and viola! No more squeal.
Loud squeal when I drive.
You need new brake pads . it has a metal tip that squeals on the rotor when they are worn.
I have a 974, 945, and 955 phones in a 2-line office. I am getting a squeal on the intercom when I call just one phone. It works fine between other phones. It worked for 2 years and then the squeal showed...
Check the battery on all the phones then make sure they are all programmed with different extension numbers. If the battery has been dead and you have had a power outage then it may have reset the phone to factory default extension 11.
Loud Squeal Heard by Called Person
Try calling up Samsung Mobile. If it's a known problem, you'll be able to ship it back to them and have them flash/fix it.
Brakes squeal
ceramic discs so they squeal until they’re warm
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
