SOURCE: Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
SOURCE: Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
SOURCE: Water spilled into the controls of my GE range top
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
SOURCE: uneven flame on GE profile
Hi, That is not that hard to fix and you can easily buy the parts yourself online...
First check the way the burner is assembled.... compare it to the other burners... seems as though it may not be put to gether properly....
However if this was a defect from new there may be a flaw or something stuck inside of it...
Probably will not get warrranty on it now... but you could try....
Anyway...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
