SOURCE: No sound from a Shure MX412D/C
Sounds to me like you may be missing a phantom power supply. The 570S is a Dynamic mic. The MX412d/c is a Cardioid and requires a 11-52v supply over pins 2 & 3 in the mic cable. Phantom power is a feature of most professional mixing consoles(usually 48v). If you do not have a phantom power supply on your system- then you can purchase single battery powered units to insert in the link between sound console and Mic. For example: AKG B-18
Hope this helps.
Rus.
SOURCE: Hi, I bought the Shure Beta
That will not work. The Beta 87H/C already has a preamp built into it. That preamp requires phantom power. The MX1BP is another preamp, so you would not need it, due to the preamp that is built in.
If you do not have phantom power available, then purchase an external phantom power supply.
Testimonial: "Solution is in fact one correct way to solve the problem"
