Question about Stanley Utility Knife
Jammed blade - Stanley Utility Knife
B&D CMM1200 won't start/blade doesn't spin. Fully charged & it tries to start - blade moves maybe 1/4 inch, there's a "clunk" & that's it. Blade, blade insulator & spacer replaced with no difference.
This suggest that there is something jamming the motor and stopping it from running. Assuming you have checked that the blades are clean and there is no grass build up on the underside, it means that there is something in the motor that is jamming it. This might be something that has fallen into it, or something that has broken. The only way to find out is to pull it apart and check what is jamming it.
May 23, 2016 | Garden
Blade stuck in dw331 blade clamp
I've been all over the internet with this because the blade clamp on my 331 is jammed as well. It turns out DeWalt has redesigned the blade clamp, I'm guessing they did this because the original design jams. Solution: call DeWalt. Tell them that you have the old and now obsolete blade clamp that is prone to jamming, and that yours is stuck making your saw worthless. Ask them to send you the new redesigned clamp that is supposed to work better. You swap out blade clamp by removing two hex head (allen) screws.
The new style blade clamp for the 331 is part number: N072135SV
*The obsolete part #: N072135, 586203-00 and 589148-00
Good luck getting DeWalt to send you the working part for free.
Jul 07, 2014 | Dewalt Saws
How can I fix a jammed Ryobi miter saw blade?
Probably go a piece of wood between black and safety cover. Unplug from power before checking
Apr 30, 2014 | Ryobi 18 Volts Cordless Miter Saw 18v P551
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Blade will not lock
I advise you to jam the blade against a piece of wood to jam the blade for removal, remember that the bolt holding your blade on is reverse threaded and self tightening so don`t over tighten.
I always use this on the job-sight for it is easer than fumbeling for the lock button with gloves on
Oct 10, 2013 | Saws
John deere js35 walk behind mower trouble shooting
It probably partially sheared the flywheel key. That's what it's supposed to do in case you jam the blade. You'll need to remove the flywheel and replace the key. The partially sheared key offsets the timing and then it wont start. First I would check to see if the crank didnt get bent when you jammed the blade. Turn the blade by hand and watch to see if it wobbles. If it does you have bigger problems.
May 08, 2012 | Garden
My cub cadet zero radius mower will die when I engage the blades. it seems that the blade is jammed but I do not see anything jamming it.
flip the mower up on its back, supporting it properly so it doesn't fall on you. you should be able to turn the blade(s) manually, if not then something is preventing it from turning. if there is nothing in the blade box jammed, it may be in the belt drive assembly, perhaps a stick or rock flew up in there and got caught, it happens quite often. the only other thing might be bearing on the shaft have locked up, but you would have heard this happening long before they actaully froze, good luck
Mar 23, 2011 | Garden
HOW DO I REMOVE THE BLADES? I THINK SOMETHING IS
i do not think the blade's are removable.look underneath unit ,in the center there may be a hex/allen bolt that is use'd to unjam the blade's/disc. it also may be easie'r to remove unit to work on
Apr 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
HR Specialist
try saturating left over paper with shredder oil and let sit for 4-5 hours or more this should soften paper enough to remove easier although it may be a little messy
Dec 27, 2007 | Office Equipment & Supplies
Stanley  Utility Knife  Logo
429 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
