Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
Air blows out top - Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
I have a coleman suncutter model 7448-801 and the fan motor was replaced but instead of it blowing out the top of unit it is drawing in from top and trying to blow out thru the coil is this accurate or is...
I have never seen one that doesn\'t suck air in through the coil and blow out the top. My guess is that the double shafted motor was installed backwards.
In cold weather heater will not blow warm air unless at idle stopped. when at highway speed blows cold air
check and make sure the radiator is full of antifreeze take off the radiator cap and top off the radiator then take your hand and cover the hole where the cap goes and squeeze the top radiator hose a few times to help it go down that way if there is a air pocket somewhere it will help push it out when you thank your done top off again and replace the cap and try
1helpful
1977 deville top ac vents not blowing; only floor vents blowing cold air.
vacum hose leaking or not functioning at all trap door to left of glove box in dash
1helpful
Wg6005ry6, blows hot air, can can i set it to blow
there is a thermoprotector on top of the compressor check that an the compasitor
1helpful
2answers
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
Heater won,t blow warm . core ok. fan runs .will only blow cold
EITHER VALVE STUCK TO ALLOW WATER IN MATRIX OR YOU HAVE AIR BLOCK IN IT. TAKE OFF TOP HOSE AND RUN MOTOR, TOP UP RAD AT SAME TIME, USED A DESCALANT IF WATER MUDDY /RUSTY LOOKING
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
Top Hitachi Tools & Hardware - Others Experts
Parson's Repair...
Parson's Repair...
ADMIN Canada
ADMIN Canada
woodzowl307
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
