Question about Honda EU6500iS Inverter Generator
My Eu6500is Inverter generator has an error code of E-10 and E-20. It will start, but then shuts off within 5 seconds. It won't stay running. Does anyone know what these error codes mean?
Posted by Wade Shaw on
2 Related Answers
Vitally Alcher
  • 1645 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
Anonymous
  • 7 Answers
SOURCE: I have a Honda 7000 EM inverter generator. When it
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Posted on Sep 10, 2009
Eu6500is generator trips to red unload when ac is on
Air conditioner compressors require a greater amount of electricity (measured in both volts and amps, but the amps are what is causing the overload). You will need a larger generator to run your AC. You might be able to run a smaller AC unit, but always check the Amps required and compare that to the Amps the circuit breaker on the generator is rated for.
May 30, 2016 | Honda EU6500iS Inverter Generator
What controlls the rpm on a eu6500is
The inverter signals the throttle motor, which is really just a small servo motor on the top of the carb. When the inverter senses more load, it increases the throttle to compensate.
Jul 10, 2015 | Honda EU6500iS Inverter Generator
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
Where can I buy a hard copy owners manual Honda generator eu6500is?
The manufacturer would be an excellent place to start... and they have superb paper manuals.
Jul 31, 2014 | Honda EU6500iS Inverter Generator
Honda es6500 won't start has fire,compression , gas, not voltage at carb, oil light on then goes out when cranking
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Apr 03, 2014 | Honda EU6500iS Inverter Generator
Stops generating and just idles
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Mar 28, 2017 | Honda EU6500iS Inverter Generator
E04 error code
Honda eu65 complaint overload indicator light on and engine shutoff
Aug 12, 2012 | Honda EU6500iS Inverter Generator
No ac ooutput
your load device problem. some one load device starting load amp high.so find it.
check one by one load connect.
May 27, 2012 | Honda EU6500iS Inverter Generator
Our Honda EU 6500 is has a e29 code and shuts off. Do you know what the code is?
Hi there
Code e-29 on a EU6500IS stands for GCU (genarator control unit) internal failure or inverter unit internal failure .The cost on a GCU is around $480.00 and the inverter is around $1100.00. On the i-monitor press and hold the button for about 3 seconds and the display will show all the error codes (5 total) . Check if there's any other error codes .
Hope this help
Jul 08, 2009 | Honda Electrical Supplies
Honda EU6500iS Inverter Generator Logo
930 people viewed this question
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
