Uniworld UGR-CH24 Griddle Logo
A
Anonymous Posted on Sep 06, 2013
How do I use the reset button? It doesn't seem to push or pull.
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
I have a riccar vibrance red vacuum, just purchased with in 6 months and the roller brush wont go on and the reset button doesn't seem to push in or work I now live in Hankinson, ND 58041...there is a...
The reset button only pops out if the vacuum motor overheats. It does not affect the brush roll. If the motor is running the problem is most likely a broken or stretched belt.
Reset button was hit but cannot log in with admin and motorola locked out and cannot get lap top to connect
It seems I didn't push the button long enough or I pushed it and then pulled the power cable. That got me into some weird condition where internet would work but was not able to login to the router.
The right way:
- Press and hold the reset button until the devices lights start to shutoff
- Wait
- Login with the defaults: admin/Motorola
1helpful
The readout on the thermostat says "bae lo". I pulled the face of the thermostat off the wall and it reset and I was able to push "run program", but the furnace did not come on.
welcome to Fixya !
here are some steps that you may follow. open the remote and remove batterys or cell of your model for six seconds (i dont know .cause you didnt mensioned the Model.) then place them back.
start the A/C again , see if it works if it doesn't then follow the lower step. and if it helps ignore the rest of paragraph
now open the Air conditioning vent and find the Sensor of the remote near the sensor there shall be a button very small one , maybe its located in a hole. check and observe keenly .
just push that button for once .it will reset the AC. to default
if it doesn't help then comment with a model no
best Regards
The chronograph hour hand on my movado series 800 is out of sync and i cant get it back to the 0 position. I have pulled out the crown and pushed the start/stop button...
Try pulling the crown out and using the reset button to move hands beside the sweep arm. If this doesn't work then you may need to take it to a repair shop that can reset or AC the watch. With a movement as fine as Movado I wouldn't attempt this yourself. If you make a mistake the repair could cost more than the watch. Be sure that you have the watch resealed so it maintains its water resistance.
7helpful
3answers
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
For Zen M: Blue ligth on continuously with new battery
have you tried doing a Software re-set. (Hold the On/Off button in the On position whilst pressing the Reset button). Then try re-charging. The device will take about 10-15mins before it responds if the battery is completely flat.
Top Uniworld Kitchen Appliances - Others Experts
john h
Are you an Uniworld Kitchen Appliances - Other Expert? Answer questions, earn points and help others
