Question about Electrolux Freezers
Freezer alarm The freezer keeps alarming and no longer seems to be running (normally very loud and now quiet). The temperature display in the fridge is flashing -18, there doesnt seem to be anything blocking the door from closing properly.
Posted by Clair Rainbow on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Posted on Sep 12, 2013
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: alarm on
hector...this sounds like icing up! First thing is to defrost this unit. The ice is preventing air flow over the coils. Shut down and get warm air to the coils. Then, let everything dry. If you leave off and open for 2 days, this will do it. Causes: humid conditions, 'window shopping' or bad gaskets. If the gasket surfaces are dirty, clean them. Test any questionable areas by taking a 2-3 wide strip of paper and close the door on it. If the paper pulls easily, the gasket is bad.
Now, clean out the condenser coils. They are located in the back or under the unit and are always painted black. Then, have a look at the compressor. It is that big black thing in the bottom with pipes sticking out of it. Look at the larger pipe. When you start the unit, it should frost and then either dry off or condense water after about 5 minutes. If it stays frosty or is not cold, you need gas. If the unit passes all these tests, you may have a defrost timer issue. Let me know.
Posted on Dec 04, 2007
Anonymous
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
John Broderick
  • 82 Answers
SOURCE: whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Posted on Sep 26, 2009
Anonymous
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Posted on Mar 22, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my bosch fridge freezer's alarm light has started
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Bosch Fridge Freezer (KAN62V40GB)suddenly started beeping and the temperature has increased. The normal alarm whent he door is not shut correctly is a continuous tone, however this is beeping like an
Check the condenser is clean and the fan running normally, Any excessive heat from under or behind is a sure sign the fan may need replacement.
Apr 28, 2014 | Freezers
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
The freezer wont go to it's normal temperature and alarm keeps beeping!
either its not defrosting or its low on freon, is there frost anywhere in the freezer, such as the back wall?
Feb 04, 2013 | Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Temperature monitor of freezer flashes
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Freezers
Dec 30, 2009 | Freezers
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Freezers Logo
545 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
David Emmel
David Emmel
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
