Question about Sylvania 6432TE 32" TV
Sylvania 6432TD Can I switch to TV/AV mode without the remote? I went through the Menu buttons on the front of the TV, but I'm not seeing the option to switch it to AV
Posted by Mike Hanks on
    Top Expert:
  • Sylvania Master
  • 76,455 Answers
No. To select the inputs, you must have a remote control.
Posted on Sep 07, 2013
5 Related Answers
ranjonski
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
Anonymous
  • 58 Answers
SOURCE: sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Posted on Aug 13, 2007
Anonymous
SOURCE: unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
Posted on May 29, 2008
Anonymous
SOURCE: how can we set sylvania tv to game mode from the front panel?
hit menu and then hit the up volume button once and thn you should have it by the way i cant play games on mine how r you playing games on yours?
Posted on Feb 22, 2009
laurachin
  • 3 Answers
SOURCE: How did you get the sylvania tv into game mode with out remote
I had to use a dishnetwork remote that I had lying around. You also may able to program a direct tv remote, replaytv remote or universal remote. I have found that putting it into 'game mode' does not work. You will not be able to change the input without a remote.
Here are the instructions for the dishnetwork remote I was using (may differ slightly from yours):
Sylvania Television codes: 733, 506, 525, 536, 566, 568, 569, 573, 600, 610, 652, 654, 656, 659, 660, 664, 665, 666, 671, 672, 674, 677, 723, 724, 729
1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
2. Look up the Code(s) for the piece of equipment you are trying to address. If the equipment is not listed or a Power Scan is desired click here.
3. Press and hold the correct Mode button (about six seconds) until all mode button backlights come on, then release.
4. Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
5. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
6. To verify the code works, press the mode button. Then try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
7. Store the remote code for future use.
8. If the remote still does not operate the device, perform the Power Scan. If still no operation, it may not be compatible with that piece of equipment.
Posted on Jul 30, 2009
How do I tune my sylvania tv model SRT2127S to video mode with out a remote
If there is Menu button on the front panel to your tV, you can get ito its menu, and can select inputs, by entering into int input selection option. If there is no Menu button, there is no other way to select the input, without a remote control
Mar 08, 2012 | Sylvania Televison & Video
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
Im want to use my sleep timer on my sylvania 6432td and i just switched to direct tv and dont have the original tv remote any way i can use this feature
I am sorry, you will need the original remote or a remote that is similar.
You can check out 1800remotes.com and see if they chan help.
Thanks
asnowman
Mar 10, 2011 | Sylvania 6432TE 32" TV
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
How to get TV off game mode without remote (not a
is there a TV/Video or menu button on the front of the tv? if so try the tv/video button, that should scroll through the the components you have on your tv. dvd, game cable etc. If no tv/video, hit the menu button and then use either channel up/down or volume up/down to scroll through your component options.
Dec 27, 2009 | Sylvania 6427TE 27" TV
How can I input my sylvania 27" into video 1 or video 2 without the remote? The menu does not offer a game option nor a video 1 or video 2 option.
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
Jul 29, 2009 | Sylvania 6427TE 27" TV
Jun 13, 2009 | Sylvania 6420FB 20" TV
Old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Jan 11, 2009 | Durabrand BH1304D 13" TV
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Sylvania tv input channel with dishnetwork remote
The remote control has a "Game" button, which is how you select the external input. Since you don't have a remote you can select game mode via the front panel Menu button:
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the VOL(ume) ▲ button so that "PICTURE" is selected.
3) Select the feature you wish to adjust with the CH(annel) ▲ or ▼ button and adjust it with the VOL(ume) ▲ or ▼ button.
GAME MODE: Set to the most suitable position for TV
GAME. [+] : ON [ - ] : OFF
This will place your TV into Game mode and use the front panel video/audio jacks.
Here is a link to download the user guide: http://www.sylvaniaconsumerelectronics.com/support/manual/index.aspx
Just enter your model number.
Please let me know if you have any questions.
Good Luck!
Mar 21, 2008 | Sylvania 6427TE 27" TV
Sylvania 6432TE 32" TV Logo
607 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
