SOURCE: Four blinking red lights.
the error code is triggered by the inverter fuses, which blow when the inverter fails
SOURCE: "Upgrade" of Backlight Panel
just replace what failed.
I replace the surface mount FETs on the inverters.
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
SOURCE: There is no picture and no sound on my sony bravia
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
