Question about Mitsubishi WD-73736 Television
Recently, my Mits WD-73736 started spontaneously switching viewing modes (normal, expanded, wide...) every few seconds, then it wouldn't turn on anymore. I replaced the lamp and the ballast board. This brought the TV back on line, but after about 20 minutes it starts spontaneously switching picture modes again. Not sure if these problems are related. Heat issue?
Posted by Joel Gerring on
5 Related Answers
Robert Johnson
  • 395 Answers
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
Anonymous
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Posted on Mar 16, 2009
texasdan
Dan Smith
  • 60 Answers
SOURCE: Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Posted on Sep 06, 2009
Testimonial: "Great comments. Quick to respond!"
Anonymous
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
How to set up for 3d viewing
You need a 3D Blue ray player and 3D glasses. Make sure that the 3D feature is turned on on your Mitsubishi. You also have to have HDMI 1.4 cables. Anything lower will not produce 3D
Apr 26, 2012 | Mitsubishi WD-73736 Television
Mitsubishi 73 inch. green light blinks for a few seconds then the status light stays on. can hear a clicking noise when the green light is blinking. Replaced the lamp and that does not fix anything.
Mits has had an excessive number of problems with color wheels in some of their optical engines. Provided you replaced the lamp with OEM parts I would suspect the color wheel is causing the noise as well as the shutdown issues.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Mitsubishi WD-73736 Television
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
Going nuts!!
If you are using Dish Network, while in SAT mode, hit the star key on the remote (also labled FORMAT). It will start scrolling through certain modes: zoom, partial zoom, normal, stretch... etc)
Jan 26, 2008 | Televison & Video
Mits WD 52525 format issue.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-73736 Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
