Jensen JCR-260 Clock Radio Logo
Question about Jensen JCR-260 Clock Radio
Alck-487 how the get 24 hour time - Jensen JCR-260 Clock Radio
Set time on a alck 487 clock
The manual has the complete process how to set time.
My clock beeps every hour how do i stop it?
You don't mention the kind of your clock. Manual or Digitally ? if it digital you have to do some like a change system alarm every hours need beep or not. Just like that. That the best way i think.
1helpful
ALCK-486 time setting
In regular mode press "M" (mode) 3 times.
set the second first by pressing the "D" (date) button to reset 0, then press "S" (set) to confirm. The minute will start flashing. Press "D" (date) to adjust then "S" (set) to confirm.Repeat the same procedure to set the hour. Press "M" (mode) button to confirm all the adjustment and return to Regular mode.
2answers
What size button battery do I need for my ALCK-487 mini clock?
There is a picture of the battery L1131 TS Button cell.
Which battery does the ALCK-487 mini-clock require?
Is this information not contained in the manual ?
2helpful
I have a small alarm clock with model # alck-487 and three buttons M, S, D. i can't find the right combo of push and/ or hold to change the time. can you assist?
ALCK-487 reset time:
Press M three times, you will see the seconds flashing.
Then press S once to adjust minutes, press D,
press S a second time to adjust hours, press D,
press S a third time to adjust date of month, press D,
press S a fourth time to adjust month, press D,
press S a fifth time to adjust day of week, press D,
Then press M to end settings.
3helpful
ALCK 487 mini clock. How do I stop hourly bleep?
I have the ALCK 487 (mini clock I can stick to anything, since it has a backing strip) and I can't remove the function that makes it bleep every hour on the hour
Answer: Press and hold "S". If you see the seven days of the week, press "M" to erase them. it will stop beeping every hour
Sep 30, 2013 • Home
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
