Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Panasonic UF-7200 error code 634 - Panasonic Panafax UF-595 Plain Paper Laser Fax
Info code 634
Communication error! press monitor button should hear dial tone if yes (good) if not check phone line make sure phone line in correct jack marked (line)make sure issue is not happening on 1 certain transmission(number)!problem if multiple numbers.
Nov 24, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What is error code 634
Error Code 634 indicates a call that was placed did not go through:
"Redial was not successful due to no response from
the called station or wrong number dialled.
Note: If busy tone was not detected, the machine will
only redial once
Sep 03, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Fax can not be send and received
press the monitor key...you should hear a dial-tone...if not try below.
Check the phone line with a regular phone plugged into the wall jack.
Mar 11, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Getting weird comm.
error code 634 means that your machine tried a phone number and reached its redial limit. does this happen to every call or just one number.
if its all the time it could be you phone line is not connected or you need to do an all job clear
Nov 26, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
587 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
