SOURCE: Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: sony svga vpl-es2 won't work
Its because for the foot there is switch who give signal to micro processor or system control.Fix it that.Your problem will solve.
SOURCE: I have a Sony VPL
May be you have couple of weeks time to replace lamp in projector and don't forget to reset lamp timer hours as procedure would be mentioned in user manual.
SOURCE: my sony vpl-es2 displays the
Your bulb is going out. replace the bulb and you should be fine.
Just remember to set back to defualt settings before your change the bulb out and make sure your give the bulb time to pre-heat before you turn the project all the way on.
