Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Sep 12, 2007
Sound but no picture
AV 4 works, but AV 1,2,3 and regular channels now longer have picture just sound. Any suggestions?
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on Sep 21, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324627
Points
2386
You say AV4, is this the HD part? And if so, then have you checked the video board area?
I think it's the av channel but not sure
Make a reset to this set. Refer its user manual for details about how to do this.
2answers
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
15helpful
3answers
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
18helpful
4answers
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Television just went to a blue screen /no sound
hi i could be wrong but normally a blue sreen means its on a AV channel i may be wrong try pressing the av button 3or 4 times
Need AV Channel
MENU ...... PICTURE ..... TURN GAME MODE ON ..... EXIT MENU ...... TURN TV TO CHANNEL 3 or 4. THIS WORKED FOR A GAMING SYSTEM AND MAY RESOLVE DVD CONCERNS ALSO.
FUNAI ............. WWW.FUNAI-CORP.COM SERVICES DURABRAND.
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
AV no longer works!?!
delma11-If your AV was working good before,it is quite possible the AV jacks are cracked away from the pcboard ass'y. If your tv goes into AV mode,try wiggling cables to see if picture comes in.You could also try changing patch cable,let me know if this helps. cooltek Feb.16/08
3answers
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
2answers
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
