Hilti 202415 PD 4 Laser Range Meter Logo
A
Anonymous Posted on Sep 05, 2013
PD 30 error code - Hilti 202415 PD 4 Laser Range Meter
Hobart AM15-1 dishwasher. Good morning, why does 'DP' appear on the display and immediately after that it starts washing and does not show the temperature on the display?
Question edited for a lot more clarity. All question need FULL 'make model (what it is)'.
Question moved from laundry Washing Machines to Hobart Dishwasher category.
'DP' or 'PD'?
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Manual just for fun.
https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf
Error code e 288 on hilti pd30
Download the manual here: https://giftrareasis.files.wordpress.com/2015/10/hilti-pd-30-laser-range-meter-manual.pdf
Also, if no joy there, check Customer Service for HIlti - they're pretty good with helping out on problems.
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Mitsubishi wd-62628 flashing error code 41 (short) now what?
Short detected in standby power supplies. on pwr PCB check the following:
1)12VS @ connector PD pin 14: possible cause;IC9A23 circuit
Zener D9A41
2)5V @ connector PC pin 8: possible cause;IC9A21 circuit
Q9A12 circuit
zener D9A47
3)4.5V @connector PD pin 16 possible cause: F9E10
F9E11
Hilti pd 30/hilti pd 40
If anyone know I need one too for my pd 32
Code p2189 code p2187 code p2189pd code 2187pd
P2189: Sys Too Lean at Idle Bank2
P2187: Sys Too Lean at Idle Bank1
The other codes P2189PD & P2187PD are pending codes.. Meaning the car will have to recheck the errors before it calls it an error and sets the engine light on. They are the same codes as the others just the PD at the end means pending.
1helpful
I have a PD code on a Hobart LXI dishwasher. What does that mean
2helpful
Trouble codes
You might want to check for a mouse nest under the Underhood fuse block, seen them chew up wiring under there many times.
U3 error for my pioneer pd-f605 100 cd player
I don't have the service manual with me at the moment and I'm on the road. I'll look up the error code and update this somtime tomorrow.
Dan
Top Hilti Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Hilti Measuring Tool and Sensor Expert? Answer questions, earn points and help others
