Samsung SGH-D500 Cellular Phone Logo
Question about Samsung SGH-D500 Cellular Phone
Bluetooth fault bluetooth on my d500 wont activate just says bluetooth activate error
Posted by shrek3666 on
  • 5 more comments
  • oz123 Nov 07, 2007
    tried everything
  • beij Dec 05, 2007
    Samsung D500 and Samsung WEP200 bluetooth headset, bonds but no sound coming out of the headset
  • kenneth williams Dec 09, 2007
    when i recieve a call i press the phone button then i lose the call.
    what i"m i doing wrong
  • reneoos Mar 12, 2008
    bluetooth and infared activate error ??
  • weberles Mar 16, 2008
    Hi There
    Bluetooth dont want to activate just show error
  • retrosent May 30, 2008
    same problem exactly - cannot activate bluetooth or infrared - i'll try the module thing 'tho.
  • issam-etud Aug 16, 2008
    i have the same probleme my phone set just bluetooth activate errore
Level4
  • 33 Answers
There are two places where can be the problem. 1. Bluetooth module is faulty 2. Infrared module is faulty. Mainly there is a problem with bluetooth module. This module needs to be replaced with hot air. It needs to see repair center. But think...Repair will cost you at least 40 pounds. Is it worthy?
Posted on Sep 22, 2007
Anonymous
    Problem Solver:
  • 6 Answers
Could be a poor solder connection on the module, it has been suggested that heavy but carefull pressure on the module can sometimes rectify the fault. Proceed with caution.
Dennis
Posted on Dec 10, 2007
1 Related Answer
Anonymous
  • 490 Answers
SOURCE: helpind to repair my D500 bluetooth error
Plz confm error message or contact service centre.
Posted on Oct 19, 2007
Bluetooth doesnt activate
just check whether your bluetooth is visible to all if not change the settings to shown everyone
3helpful
Samsung sgh-d500, blue tooth and infrared not functioning
on phone go to menu/settengs/ok/scroll down to connectivity/ok/two choices here, bluetooth/infrared/ok/look at your choices here that should get you going? any problems let me know,
Bluetooth freeze
I flashed mine ,now its ok
Bluetooth wont activate
you need to go to unlock phones .com to restart your buletooth it works
Bluetooth error and infa
your bluetooth inside the phone does not make proper elctrial contact on the board ta it to the service provider to re install the bluetooth device. advice by dogy.
1helpful
Bluetooth
I know that it is not very helpfull to say this,but you are not alone with this fault which appears to be quite common to the D500.I assume that the same notice appears when you attempt to activate IR as this is usually the case. The only suggestion that has been doing the rounds is as follows. Remove the back and look at the chassis and you will see a square IC unit near the battery connectors. Apply heavy but carefull pressure on this and try the Bluetooth again. This is said to have cleared the fault in at least two cases.
Dennis
Helpind to repair my D500 bluetooth error
2answers
Bluetooth and infared
check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
Bluetooth
you have to rehot or change the bluetooth ic.it is near sim card reader with metalic color
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
Muzahura Frank
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
