Car Audio & Video Logo
Posted on Sep 12, 2007
Pioneer CDX-P1250 CD Multichanger
Hi iam trying to install my cd changer in a bmw convertible in the boot i have fed the wire in but nothing seems to b happening i do believe i have found a good earth or have i not can you advise please cheers,
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 11, 2007
SOURCE: No power
You have 12 volts constant on the yellow and 12 volts Switched on the red (when the car is in Ignition/Accessory)? If so, then, yup.... service shop.
Anonymous
  • 93 Answers
  • Posted on Nov 01, 2007
SOURCE: Pioneer CDX-P1280 12-Disc CD Changer not working,
sure............give the details of your problem and we will solve it
A
Anonymous
  • Posted on Jul 18, 2008
SOURCE: Pioneer CDX-FM61 CD Changer
I contacted pioneer on the issue and they informed me that on the older models such as this one if the radio picks up anything on 89.1 or 89.5 then it will not work due to the fact that these are the only stations it functions on.
Anonymous
  • 199 Answers
  • Posted on Nov 25, 2008
SOURCE: cd changer connector layout
In a word, no.
the data from the kenwood will not make any sence to the pioneer
you will need a Kenwood Cd
Mark Lewis
  • 105 Answers
  • Posted on May 21, 2009
SOURCE: radio and cd changer for bmw m3 e36 ea88906
If you go to www.crutchfield.com they will have a menu for all upgrades to your vehicles sound system including which head units (or stereos) will fit your Bimmer.
~Stillin~
2helpful
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
1helpful
3helpful
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
No installation instruction for pioneer cdx-fm128
the manual is really same with cdx fm-1277. Just look at the 1277 masual it will help you.
2answers
6 CD Multichanger
Hello There.
My guess would be that your sat nav was retro fitted, i'e not factory fitted. Who ever fitted it didn't use the correct wiring harness. It seems they may have used a wiring harness which didn't have the connection for a CD changer.
If you want to get this fixed you will need to replace the wiring harness which means stripping out the entire interior of your car, i.e seats, carpet, door panel. or you can live with the single CD which works.
If my answer has solved your problem, please rate me on fixya.
Thank you
2helpful
2answers
Pioneer Car CD Changer CDX FM673 Error Message
can anyone tell me were to get a installation manaual for a pioneer cd changer (cdx-fm67)
Connceting a pioneer cdx - p670 to avic x1 head unit
the changer is either incompatible or the changer wire has been intrnaly dammaged to much bending shorts them out as the wires are no more than alluminum foil enclosed in shrink wrap
2answers
2answers
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
No power
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
