Question about Stanley Utility Knife
Stanley utility knife 10-499, cannot re-assemble after having to open it
5 Related Answers
mark24354
Mark T
  • 776 Answers
SOURCE: WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Posted on Nov 20, 2009
ADRIAN
  • 313 Answers
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on Jul 31, 2010
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
lstimo
  • 27 Answers
SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Posted on Apr 21, 2011
Jeff Harris
  • 81 Answers
SOURCE: Have a Stanley Fat MAx
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Posted on Jun 26, 2011
How and where do I buy the furi pro cooks knife 20cm in Christchurch.
In terms of functionality and features, Stanley FMHT10288 Retractable Knife is quite satisfying. The knife is considered as one of the best kitchen knives. The price remains in the lower range. So, as a budget friendly option, Stanley FMHT10288 Retractable Knife can be quite a fine choice for you indeed.
Nov 23, 2017 | Stanley Utility Knife
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
Jun 26, 2011 | Stanley Utility Knife
HOW TO OPEN THE 10-777 UTILITY KNIFE
This is the closest thing I can find. Click here.
Otherwise, write Stanley support and they'll answer you here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 07, 2011 | Stanley Utility Knife
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
Apr 21, 2011 | Stanley Utility Knife
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
Sorry.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Stanley  Utility Knife  Logo
712 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
