Question about Haier HVT12ABS Compact Wine Cooler
Not cooling-- fan works model hvt12abs - Haier HVT12ABS Compact Wine Cooler
Posted by Anne Perry on
Fan won't work
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
------------These will help.Thanks.
Nov 27, 2012 | Cars & Trucks
Runs but does not cool. Can you suggest hot to fix?
check to see if you can hear compressor turn on.if not then the relay may be bad.could also be a leak in the system.
Mar 05, 2009 | Haier HVT12ABS Compact Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier HVT12ABS Not cooling noisy motor
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you bought it before 2006 you have 1 year parts and labor, and 5 years on the motor ! if you called them and they told you one year, they must not have known the date you bought it!
Try the manufacture!!!!!!!!!!!!!!!
They will have the part
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Please rate me solved before you sign off.
Thank You
Sep 14, 2008 | Haier HVT12ABS Compact Wine Cooler
Wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Jun 21, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier HVT 12ABS fan runs, but fridge does not get cool
Hello warmfridge
happy to assist you,
You said,
We've had this wine fridge for about 3 years now, and all of a sudden it stopped getting cold. We still hear the fan turn on and all appears to be running smoothly but it remains room temperature inside. Does anyone know how to fix this? I have no experience, but would like to try rather than buy a new one. thanks!
1. You may need to add freon.
2. It may have a faulty thermostat.
It seems you need hands on service!
Our site has good companies in the repair directory.
Bless you,
please rat me here before you sign off.
Thank You
Jun 09, 2008 | Haier HVT12ABS Compact Wine Cooler
My wine cooler does not cool
others have writen in one of your fuses (sodered in) my the bottom one.
not sure why yet.
May 26, 2008 | Haier HVT12ABS Compact Wine Cooler
Problem with cooling of HAIER HVT12ABS
not to much experience with tecs, but a tec has a hot and cold side so turn the tec around and that should solve your problem and also some good thermal paste should be used on the hot side. good luck and let me know how you got on.
Feb 22, 2008 | Haier HVT12ABS Compact Wine Cooler
If the unit has an internal fan it would be ok to use it as a built in.
Nov 16, 2007 | Haier HVT12ABS Compact Wine Cooler
Haier HVT12ABS Compact Wine Cooler Logo
51 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
