SOURCE: Photosmart 2575 printer is offline - won't print
I have the same problem and i have no idea how to fix it please help!!!!!
SOURCE: Can't print because of Error-offline status.
I found out that the IP address on the printer was different from the IP address that was available when the printer was first installed. After spending days trying to fix this, it was resolved in less than two minutes.
Go to the Printer Folder in the control panal and choose to Add a Printer. You will see the option to add the new printer ( wireless). Chose to install, and it will install the printer under the new IP address. It worked instantaneoulsy.
You also need to make sure the IP address is inputted into the printer ( check your guide for how to input the IP address)
What I dont know how to do is to keep the IP address static. Afger, it is not practical to do this each time it changes. If only the last digit changes, it may be as easy as switching to the printer available under the current IP address.
Cheers,
DeniseA
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
SOURCE: HP 1315xi psc all in one error offline
Go to Control Panel- Printers
Right-click on your printer and click on Use Printer Online.
Hope this helps!
