Are you seeing a cleaning light or is it just ejecting the tapes? If it is ejecting them then make sure to try a brand new tape of the right type (if it is the wrong tape type it will eject).
Also try a cleaning tape if the cleaning light is on.
If that does not work then you will need to send in the tape drive somewhere for repair as the head might be worn out or the drive needs a good service.
Try going to http://tape-drive-repair.com who sell and repair these units. The LTO2 and LTO3 drives are pretty inexpensive now and so this should be fairly cheap to have sorted.
Also this unit is the same as the Quantum superloader3 so that might help if you are still googling for a solution
SOURCE: StorageTek L40 Tape Library
how to change backup tape in storagetek L40?
would appriciate very much if you could reply me!
Thank you!
SOURCE: scsi tape drive not recognized on the library
Please check your firmware on the tape drive. Update with X-Talk software that can be downloaded from www.quantum.com.
SOURCE: StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
