BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger Logo
Question about BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger
I forgot my password on my HTC windows samsung kais160 passcode. Anyone know how to reset the phone to factory settings?
raseena nizar
    New Friend:
I need install whats application
Posted on Sep 06, 2013
HOW TO FACTORY RESET BECAUSE I FORGOT PASSWORD TO UNLOCK PHONE
the link below shows a video of a Samsung being reset.
hope it helps, press the helpful button
Remove Forgotten PASSCODE PASSWORD Unlock For ALL Android Devices...
Help How do I unlock my screen ? I forgot my entry password
Hi Barbara,
How to unlock screen If you forgot password on Windows Phone 8
You have to reset your phone to factory settings to unlock screen. There is no other way to reset lock screen password. If you reset your phone, You will lose all the data like photos, videos, contacts, sms etc. If you have cloud backup enabled, you can restore data from backup after resetting Windows Phone.
Method 1:
You can't use soft reset as you can't get past the lock screen. You need to hard reset phone using hardware keys like Volume, Power buttons. It is very easy to hard reset Windows Phone. It does not take long to reset phone. You can read instructions for hard resetting Windows Phone 8 here.
Method 2:
One of the features of Find My Phone on Windows Phone site is Erase. You can erase or reset your phone remotely by logging into Windows Phone account. on the Microsoft Windows Phone website.
Go to Windows Phone - Find My Phone page and login with your Microsoft or Hotmail or Xbox or Outlook account you used on your Windows Phone. You can do this on your computer. You will see the option to Erase your phone. Microsoft sends a sms message to your phone to erase your phone.
If you have push notifications turned on under "Settings > Find My Phone > Send apps to my phone using push notifications (not SMS), You can erase phone If you just have WiFi on your phone and don't need to have cellular signal.
Your will be returned to factory settings. You will need to setup your phone again.
These methods should work on any Windows Phone 8 including Lumia 920, Lumia 820, Lumia 810, HTC 8x, Samsung Ativ etc
Sep 25, 2015 • Cell Phones
3answers
Reset my password on iPhone and i pad
iPhone must be recovered on a PC or Mac to solve this problem.
CLICK HERE
5helpful
4answers
How to reset password on iphone without itunes
If what you say is iPhone backup password, just with a computer and a tool, iPhone backup password will be reset.
iTunes Password Genius can run in Windows computer. What you need to do is run it on computer, add iTunes backup into it, and set password attack type for backup password recovery. Once all of these done, click "Recover" button is enough.
But if you want to change or disable iPhone backup password, you need to connect iPhone to computer and do that in iTunes.
If the password you say is iPhone passcode, factory reset iPhone is a method. You can reset a new password for iPhone after factory reset. However, all of things on iPhone have deleted too. Now restore iPhone from iTunes backup on computer is a best way. The backup password could be recovered with iTunes Password Genius.
How can i reset my phone because i locked it and forgot my passcode
Factory / Hard Reset : *2767*3855# (All data & setting in phone erase & reset to factory default automatically without warning)
That code is only for Samsung
13helpful
I samsung highlight t749 security passcode reset
easiest way is to open up your dialer and type the following code: *2767*3855#
If you get the unlock password screen at boot up, try hitting the SOS in the bottom left, if it brings up the dial screen then type it in. It will reset the phone to factory settings and reset the password to 0000. You can then confirm this worked by going into menu/settings/reset settings/master reset. Then type in 0000 when prompted and again to verify. If your phone resets again then you know your password has been reset to factory default.
I forgot my PIN password to my samsung A737
well, if you made your own personal password, then your out of luck
but if you didn't,
the passcode is usually 1234, 0000, or the last 4 digits of your phone number
Sep 22, 2009 • Cell Phones
I forgot my mobile password not able to restore the factory settings of dopod D 600 HTC phone I typed a password, and i forgot it
YOU MUST NEED TO READ YOUR USER MANUAL FOR YOUR MOBILE PHONE. THE SOLUTION MUST BE IN IT TO RESET YOUR PASSCODE.
IF YOU CAN DO SO YOU MUST HAVE TO GO TO THE MOBILE SERVICE STATION TO SOLVE THE PORBLM.
PLS. RATE MY SOLUTION
HAVE A NICE DAY
KETAN
11helpful
2answers
PASSCODE HOW DO I RESET THE PASSCODE?
You cannot reset the passcode, however the default passcode is "0000"
Open Questions:
Top BargainCell Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a BargainCell Cell Phone Expert? Answer questions, earn points and help others
