Computers & Internet Logo
Question about AKAI Professional M.I. Corp AKAI S5000/S6000 Midi Stereo Digital Sampler
64 bit driver for USB control of Akai S5000
Is there a 64 bit Win 7 driver for the USB control of the Akai S5000? Works fine with XP 32 bit.
Posted by Pete at Pennyland... on
rajat arora
  • 136 Answers
Not available..sorry...
Posted on Oct 16, 2013
P5PE-VM with Win7 has no display on PCI video cards-EVGA 2600 or EVGA gt 220. Both cards ran fine with Win XP. What do I need to do?
Hello here is the mainboards homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Are you running 32 or 64 bit system ???
Make sure the video driver supports windows 7, 32 or 64 bit.
The video card can sure run fine on windows xp but not in windows 7 as it is a totaly different system.
The mainboard has a 1 x AGP 8X slot.
So now you maybe has to find a video card that supports windows 7
Try also to download a manual.
Good luck
I lost my cd hp deskjet f380, and i need it for my new laptop.. I don't know how to download it ... do I have to use USB? thank you
yes you need to use USB .. You did not mention which operating system you are using so i'm guiding you with all option which i feel is important.
If you are using Win Xp 32 bit Than Click Here.
If you are using win xp 64 bit than Click Here.
If you are using win Vista 32 bit, Click HERE
If you are young win Vista 64 bit, click here
For win 7 you just CLICK HERE.
Hope now you can download your driver...
1helpful
I have a micromax 310G 3G USB modem. It works fine with XP and Win 7 32 bit OS's but it does not work with Win 7 64 bit OS. I keep getting "dial failed". Pls help me out.
Check whether modem is installed properly(You may check this using device manager) and check whether following services are started or not. - Remote Access Connection Manager - Remote Access Auto Connection Manager
I have lost my software disk for QX5 digital blue microscope we are a school and have a mix of computers xp vista windows 7 what do i do?
Here are the links to the available downloads from Digital Blue:
QX5/Smithsonian Computer Microscope Drivers for WIN ME, 2000, XP, Vista 32-Bit
Download Drivers
QX5 V2 Computer Microscope Drivers for Windows Vista 64-Bit
Download for Windows Vista 64-Bit
QX5 V2 Computer Microscope Drivers for Windows 7
Download Windows 7 32-Bit
Download Windows 7 64-Bit
QX3, QX5 V1, QX5 V2 Computer Microscope for Mac OSX 10.4-10.6
Visit Webpage for Download
QX5 Computer Microscope V1 Video Codecs for 32 bit versions of Vista/Windows 7
Download Codecs
We lost them!)))
Download Drivers
Download Codecs
3helpful
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
1helpful
I need the softw for microscope qx5, i am of Chiapas Mexico thankyou
Download Drivers
7helpful
2answers
Windows 7 drivers for minolta magicolor 2300dl?
Two Minolta 2300DL windows 7 64-bit solutions(choose oneoption): 1) Download the XP 64-bit driver and extract to a folder: ftp://ftp.minolta-qms.com/pub/crc/out_going/windows/2300d_64b.exe then Control Panel>Devices and Printers>Add aprinter> Add a local printer>choose USB printer port>select the "HaveDisk" button(do not select a printer) and browse navigate to where you savedthe XP 64-bit driver "MLUU_DRV.inf" driver file which installs and worksfine. Only issue is now have a 3 minutewait delay for each print job using the universal driver compared to no delaywhen printing with XP. OR 2) Follow the Vista USB port(not network) install guide butstill use the XP 64-bit driver. ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf 3) 32-bit option use the Vista 32-bit driver first as thatshould work.
10helpful
4answers
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Top AKAI Professional M.I. Corp Computers & Internet Experts
Marvin
Marvin
Are you an AKAI Professional M.I. Corp Computer and Internet Expert? Answer questions, earn points and help others
