Question about Toshiba Televison & Video
Remote to an OLD Toshiba TV (model 37a33) is lost and I'd like to replace it OR possibly use cell phone for IR signal. Reason is I want to change video source but TV does not have button to allow it. Any ideas?
    Top Expert:
  • Toshiba Master
  • 76,171 Answers
If you wish to buy its original remote control, contact the authorized service center for Toshiba. If you wish to buy a universal remote control, check the code list to the remote control you do buy, have set-up codes to Toshiba TV. Setup codes to Toshiba are
1088 1077 1061
1070 1203 1423
1093 1466 1048
1213 1047 1141
1046 1231 1144
1276 1054
If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, and find out which brand remote control have setup codes to your Toshiba TV, and buy that brand remote control according to availability. Brand name to a universal remote isn't a matter, but it should have setup codes to Toshiba. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Posted on Sep 05, 2013
6ya staff
SOURCE:
Pravin Gupta
  • 275 Answers
SOURCE: Lost functionality w/ Universal Remote
Now, it depends upoon the Universal Remote u purchased. If your remote has the neccesary buttons - AV/TV switching,Front - Rear Input Switching, Menu, etc, it should work! Since there are multiple codes for every brand, keep feeding the various codes one by one, and checking if the neccesary functions operate. If, finally, you are unsuccesful, then, folow techman's advice. Best of Luck.
Posted on Jul 22, 2006
jason
  • 905 Answers
SOURCE: component input- no audio/video signal
copy protect circut may be going bad or the component cicut has now failed
Posted on Oct 07, 2008
Anonymous
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
Anonymous
  • 15 Answers
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Posted on Jan 12, 2009
Anonymous
SOURCE: TV stuck on Video
I had this problem, I replaced the remote and it works now
Posted on Nov 03, 2009
Hi I have samsung TV Model# LN46A650A1FXZA. Remote for this tv is not working. I tried replacing batteries, but even then it is not working. Any possible solutions????
The problem could either be with the remote infra-red (IR) transmitter or with the TV IR receiver.
There is a simple DIY way to check whether your remote is still sending a signal to the TV. The infra-red flashes from the remote cannot be seen with the naked eye, but they ARE visble when viewed through a video camera. It's easier to do this with 2 people, but it can be done by one person with the camera in one hand and the remote in the other.
Turn the TV off and point the remote at the video camera and press several buttons. If you CAN'T see the flashes through the camera view finder, it's likely the IR transmitter in the remote is dead or there is some other major fault with the remote. the simplest thing to do here would be to replace the remote. If you can see the flashes, it's likely to be the IR receiver in the TV, but this isn't really a DIY fix.
I've used an analogue (tape) video camera for this test, but there's no reason why it wouldn't work on a digital video camera or possibly even a digital/phone camera.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Remote Control
Toshiba 36A50 no longer responds to remote controls.
The only common problem would be on the Toshiba Remote. Make sure you have the switch on the remote set to "TV' and not Audio, or Video. Beyond that, if you have a digital camera or a cell phone with a camera with a viewing display, point the remote at the camera and push any button. If it is sending IR, you will see the flashing from the remote on your camera/phone display.That will just confirm the remote is sending signals. The only other possibility is that your IR receiver on the TV is bad, This happens, but it's not very common. Hope this helps
Sep 30, 2010 | Toshiba 36A50 36" TV
No remote control will work the tv anymore. Could
Hi I am Vortash , Its possible the IR detector has gone but unlikely , it is more likely that due to a low battery in a remote the signals have corrupted the remote processor this used to happen a lot with the old EMI and Bush sets and sometimes it is just a fact that the remote has given up the ghost . You can check to see if your remote is working with your Iphone or any phone camera . Put the phone on record and place the remote in front of the lens , if it is working you should be able to see the infrared diode flashing in the phones viewscreen . If it is working you will need to find out the de- corruption proceadure for your model of set hope this helps regards Vortash
Mar 30, 2010 | Toshiba 42H83 42" Rear Projection...
Tv not taking remote signal
First check if the remote works. This can be done by using a digital camera or cell phone camera. Point the remote at the camera lens and start pressing buttons on the remote. If you see a blinking light on the LCD preview screen of the camera, then you know the remote is transmitting.
If the remote is not transmitting, replace the batteries. If this still does not work, you should get a new remote.
If the remote is properly transmitting, then the issue is going to be with the TV. It depends on the type of TV you have but usually is either the IR sensor board or the main board which are in charge of receiving and decoding the signal from the remote.
Oct 13, 2009 | Televison & Video
Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 01, 2009 | Toshiba CF32H50 TV
A Toshiba TV 27A45 was given to us. TV works fine,but Remote no.
Hello.
There is a simple way to test to see if you IR port on the remote is working. View the IR port using any digital camera, camcorder or cell-phone camera view screen. Through the view finder, the remote signals appear as a flashing blue light (whenever a button is pushed). Even the old-style VHS, VHS-c, and Hi-8 video cameras can "see" a remote's infrared signal.
Just so that you know what to expect, do this experiment using remotes that you have that you know work OK.
Apr 11, 2009 | Televison & Video
Tv will not stay on just tv
Look at the IR emmiter "eye" on your remote thru your Cell phone camera. You can tell if the remote is constantly emitting a signal.
Jan 27, 2009 | Toshiba 32AF43 32" TV
Locked remote
i know this may sound silly but check the batteries. now if you allready changed them and your still having the same problem check the ir signal on the remote. now all you have to do is take any camera( camera phones work just as good) hold it to the ir sender on the remote press any button on the remote and look through the view finder on the camera. you should now see a light go off on the remote through the camera. if you dont see a light then you have yourself a broken remote. if you do then its possible its the tv ir reciever. and may need to be serviced. but hoping its the remote you can always get a replacment remote for cheep.
Jan 26, 2009 | Hisense TC24FS2H TV
My LG remote control turns two TV's on simultaneously
I had the same problem and we cut up a stick on lable and placed it over the end of the remote . It weakened the signal enough to where it would not change the other tv/tvs. We colored in the white lable with a black marker and you dont even notice it there.
It took alittle playing around with but it was much cheaper than buying a remote.
Dec 01, 2008 | LG Shine KE970 Cellular Phone
Funai 13" TV with VCR Combo
You can check the remote by holding it very near an AM radio. Have the radio turned on and tuned about the middle of the AM broadcast band and push the button on your remote. You should hear a popping sound come through your radio speaker. If you can't hear anything, try moving the remote around and tuning the radio. If all fails then the remote is not working. If you DO hear the popping sounds then you have a problem with the IR receiver in you TV. There's a little plastic "window" in the front of your set where the IR signal enters. If dust has collected on the inside this could block the IR signals from entering. Also the IR receiver itself may have gone bad. The remote for this TV has to be an exact replacement. I've had this problem too by trying a substitute. Stargazer
Mar 10, 2007 | Funai F413TA 13" TV
Televison & Video Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
