Creative Labs ZEN Vision:M Digital Media Player Logo
Question about Creative Labs ZEN Vision:M Digital Media Player
MP3 I HAVE PUT BRAN NEW BATTERRIES IN I HAVE TAKEN OUT THE BATTERY FOR 30 MIN TO RESET IT BUT IT STILL TURNS ON SHOW THE DISPLAY AND BACK OFF IT WILL DO THIS REPEATLY THEN IT WILL PLAY 1 SONG AND GO BACK TO ON OFF THE LOCK IS OFF THE BATTERY AREA IS CLEAN IT IS REALLY MAKING ME UPSET I WALK EVERYWHERE AND NEED MY MUSIC I HAVE A RCA MP3 M202E RA128H021AA0C0 X2301 THIS IS EVERYTHING ON THE BACK OF THE PLAYER ANY IDEAS
Posted by candiebar on
Anonymous
    Problem Solver:
  • 55 Answers
Sounds like the battery connector is loose and needs to be re-soldered onto the board. You need to make sure this is correct; connect your zen to a wall charger for 30 mins and see if it behaves the same way. If it does the same thing, its not the battery connector, its the motherboard. Is the zen recognized by the computer? If not, bad motherboard. If recognized, upgrade the firmware from www.creative.com/support --> downloads
Posted on Sep 18, 2007
LOST ANTITHEFT KEY UNDER DASH. HOW DO I BYPASS TO START CAR
Try put key in ignition turn to on just before it turns over and put battery charger on battery. Let it sit there for 30 min then turn off and do it again for a 5 min , then after the 5 min turn off and try to start it
Hi, I have a Samsung R1 mp3 player. The battery had completely run out so I put it on charge and it starts up with the samsung screen then it goes onto the R1 on the screen but it freezes after that! I...
Some batteries never recover from an over discharge condition. When you connect it for charging it will show recharging indication but won't soak up any charge. Only way out is to replace the battery especially if its more than 2 year old when you over discharged it.Over discharging is when your battery voltage drops below 30% of its full voltage.
Can't turn on sansa player
try pushing the power botton on for ten seconds and then try or hook it back up to you computer for about 30 min and try again .... your battery might not be holding a charge (you might need a new battery)
2answers
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Jensen mp3 smp 2 GBL
Try using updating the firmware from manufacturer's website.
2answers
The words on my RCA M4208RD mp3 player won't show up.
Go to the main setting of your player.Turn power saver off. Also set sceensaver to 1 min.
Unable to get out of microphone mode.
Well, you can't reset it unless you are in the main menu... or if when you connected your Creative Zen Nano Plus you got a programme called Creative Media Lite you can reset it. That option only works if you connect you player to the USB drive. If you are new to the Creative Zen Nano Plus, you might not have figured out that if you push in the fast forward/Rewind button in (not left or right, in), you will get a menu. By the way I meant connect the player to the computer. Sometimes if you take the battery out of the MP3 and leave it for 30 seconds, it will reset itself. If all else fails, I am sincerely sorry but I hope I helped!
MP3 player something wrong
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
2answers
Fried?
that happened to me...what i did was a just left my Sansa on until the battery ran out and then charged it.
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
