SOURCE: Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
SOURCE: can i shorten
The blowing of the breaker has nothing to do with the hose.....
The problem you have is that you only have a 15 amp. circut to the washer... this is okay for many washers, but some will pull too much surge current especially when the motor starts.... this can trip a 15 amp. breaker...
You also could have a weak or slightly bad breaker there....
the first thing i would do is to change the breaker with a new one...do not change it to a higher amperage breaker if you do not have 12 ga wire....14 ga wire can only handle a 15 amp. breaker and 12 ga wire can handle a 20 amp. breaker....
If you only have 14 ga. wire to the washer and a new breaker does not fix the problem, then you may have to run a new 12 ga. wire to the washer...
heatman101
SOURCE: Kenmore front loader Model Number 970-C42162-00
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
