SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
SOURCE: I have lost manual to
Here is the link
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=hqktGGuVh.IjhJvcv4
Hope it helps
Thanks
Please rate FIXYA
SOURCE: How do i change the oil on a 2500 troy bilt
if its a vertical shaft engine tip it on it;s side and drain it from the dip stick tube
