RCA RS2604 CD Shelf System Logo
A
Anonymous Posted on Sep 04, 2013
Service manual CD tray out of sync.
tip
HARMAN FL8385 CD CHANGER TRAY ALIGNMENT
We've all done it, or one of our youngsters do it for us... knock the multi disc tray out of sync with the drive gears.
With multi disc trays, the CD drive has to move out of the way during disc change and tray loading. Occasionally a disc jams, someone forces the tray movement, and you hear the GRIND, GRIND, GRIND of slipping gears.
Most designs have a switch-hit gear setup that's self correcting for small adjustments but occasionally the mechanism slips beyond self correcting.
Here's the process to open up and fix the tray alignment for Harman's FL8385 CD Changer.
http://www.keepandshare.com/doc/view.php?id=1660661&dn=y
3.7mb PDF.. (I'll try to shrink the filesize later)
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
CD tray won't open or close on onkyo dx-c606 cd changer.
Yes! it sounds very likely that a small loading belt has stretched, or the loading motor is not working, this is not an easy repair because the gears are timed and synced to work together, if the unit has a loading belt pull tray all the way out and look in the empty tray, may be visable! if you can remove it without taking it apart all the better, have a Tv repair shop size up the belt for replacement.
Cd tray stuck
The tray may be jammed, or the timing gear is out of sync, or a broken loaing belt.
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
2answers
CD tray on Technics SL-PS670A compact disc player will not close
Just a quick notion! Had you made sure the transit locking pieces were removed?
4helpful
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
Sony model # CDP-CE415 Tray alignment off when closed
Your goin to need to re align the tray , your gonna need the service manual for this purpose. Go to this link :
http://www.nodevice.in/manual/Sony/page15.html ,hope this helps you, AJ
Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
