Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
John
