SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
SOURCE: miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
SOURCE: Electrical power down while vacuuming (not a reset)
Thank you JonahBegone!
My 4 years old Silver Moon has been power down off and on for a couple of months, but all of sudden it kept doing it. Then the power won't turn on when I plugged it in ( this turns out to be another problem, see my other posting). I took your advice on taking the hose and handle apart. I unscrewed the 5 screws, but can't pull the handle apart to look inside. I was able to see the 3 metal contact on the hose that you mentioned through a 1/4 inch gap when I forced the handle apart. I cleaned the black stuff off through the little gap by rotating the hose a few times. Then magically, my power down problem also went away. Thank you once again.
