Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
Jason Ramirez Posted on Sep 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the Toshiba IC 386513 from a Sony Trintron 36" TV the Same as the one needed for the Sony Wega (Model KV34HS420) IC MCZ3001DB?
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Sep 05, 2013
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005489
Points
237762
5 Related Answers
A
Anonymous
  • Posted on Aug 05, 2008
SOURCE: sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
rajanshyam
  • 11 Answers
  • Posted on Aug 31, 2008
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Anonymous
  • Posted on Nov 12, 2008
SOURCE: SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Anonymous
  • 1274 Answers
  • Posted on Feb 18, 2010
SOURCE: No power up light blinks 7 times
this is a high voltage shutdown.......the high voltage has exceeded 33k,.....it causes the unit to shutdown for safety.check the power regulation as well as horizontal circuits.hope this helps
Christopher Stearns
  • 101 Answers
  • Posted on May 30, 2010
SOURCE: My Sony WEGA Trinitron 36'' TV has red instead of
try this reset in this see if it works
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Sony Wega trinitron TV wont turn on..Keeps shutting off and standby flashes 7 times
Thank you for your question.
Fortunately this is a common symptom and there is a fix for it.
There are two power supply IC's and a capacitor that need to be change. In particular IC6501, IC8002, part number, Mcz3001db, and C6556, 33uF @ 160V.
Standby light is blinking 9 times. what does that mean and what should i do about it?
You have a bad MCZ. Try taking a blow dryer to the right side of the TV to see if this fixes the problem.
http://cgi.ebay.com/LOT-2-MCZ3001DB-IC-SOCKET-MCZ3001D-670581001-/220499156868?pt=LH_DefaultDomain_0&hash=item3356c61f84#ht_1871wt_1020
You will have to find these and replace them both on the board to the most left of the T.V. There are two of them. The one closest to the back of the T.V. is probably the problem.
Tv sony vega mod kd-32es170 solo intenta arrancar led verde se keda ensendido yel rojo parpadeando ya le cambie mcz3001db ysige igual me podrian dar agunos consejos
tiene malo el ic que controla el alto voltage , este ic esta localisado serca del flyback ( transformador de alto voltage) # de parte mcz3001d , alo mejor el que esta el tv termina con el letra b , reemplace este ic y el tv funcionara ,
2helpful
2answers
Ebrom(memory ic) number
try to find the service manual of the tv to locate the ic.these tv,s have the icom ic and the memory in a separate pcb.this pcb is a complete part.you must change all the pcb to solve your problem.the fault ic is the icom not the memory.
3helpful
What lamp do I need?
The Sony KV36XBR800 is a direct view Tv not a DLP and doesn't have a lamp. The common problem with those units, for what you've described is Ic8002 Sony p/n# 8-759-670-30 is a Mcz3001d Ic located on the D board. I did two of these in the same week about three weeks ago. The suffix (d) isn't important either a MCZ3001 or MCZ3001DB will wrok just fine. What I do is install a footing first and simply plug the new Ic in rather than subject it to all the heat. Also check R8051 (fusible) for open.
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
2helpful
3answers
Sony model # kv-36xbr800
The standby light should be blinking a repeating count with a 2 second pause between counts. Can you post hte count here please? That will help to determine the effected circuit and the solution.
Thanks,
Dan
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
