Question about Kenmore 23822 Top Load Washer
Kenmore 80 series 23822100 type 111 won't spin, but will agitate and drain. If I manually start it spinning, it will continue, but unable to start on it's own most of the time.
Posted by Tara B on
5 Related Answers
Anonymous
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: 80 series model 23822100 will agitate but won't
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: There is no need to drain the washer to repair the lid switch. However, if you need to drain the washer to avoid having stagnant water in the tub, you can by-pass the lid switch. Use the steps provided to access the lid swtich. Unplug the switch and remove it from the washer. With the switch in your hand, cut the connector plug off leaving about two inches of wire. Cut the center conductor (green wire) off flush with the plug. Take the two black wires and crimp them together and insulate with some electrical tape, or use a wire lug. You now have made yourself a by-pass plug. Plug this back into the timer plug and you have now by-passed the lid switch.
NOTE: This is to only be used as a TEMPORARY means of operating the washer and not as a permanent fix. The lid switch is installed as a safety feature to stop the washer motion when the lid is opened. Without it, you will not be able to stop the washer unless you push the timer knob in. Make sure you replace the lid switch.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 10, 2009
Anonymous
  • 1937 Answers
SOURCE: my kenmore series 80 wont drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23822100&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
I'm assuming that it will neither drain NOR spin.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Apr 19, 2010
dannydoesita
  • 777 Answers
SOURCE: washer will not spin. water
With old washers and with new washers sometimes you have to get in there and tighten the belt or replace the belt. Your problem sounds like this to me.Your question was posted sometime ago and you probably found your problem. If not please get back to me and I will be happy to help some more. GOOD LUCK.
Posted on Sep 17, 2011
headstrong56
headstrong56
  • 493 Answers
SOURCE: kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Posted on Jul 15, 2012
2answers
Kenmore washer 80 series Type 111 Model 24872300 Filled with water but will not agitate, spin or drain.
if everything works but it wont spin, you need to replace your agitator dogs. they are in the top of the agitator. one bolt under the agitator cap. the dogs come in a 4 pack and cost about 3 bucks.
1helpful
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Kenmore 80 series washer fills but does not wash/agitate. will spin and drain when manually turning dial to spin
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
1helpful
I hope you can help me
Replace the coupler between the motor and pump. Coupler about 18.00 dollars at Sears parts store.
6helpful
3answers
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Kenmore 23822 Top Load Washer Logo
Dale Copeland
Dale Copeland
Pieter Vleeshouwers
Pieter Vleeshouwers
