If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
? 1:26 https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
www.fullsizechevy.com > ... > Technical / Maintenance Jun 19, 2005 - 17 posts - 9 authors
The truck will start but then die right out. I can do this all day long with the same effect. I can however keep it running by feathering the throttle. if ...
Well put some gas in it man! No, seriously, a vehicle runs on the physics of three principles. Fuel, air and ignition or "explosion" of gases. You have eliminated two of these principles since the engine "starts" but will not stay running. Most likely because of it lacking "fuel" or the pressure thereof. Only two things to check. Fuel pump, and filter.
The damage is already done before you put the fuel filter in. (dirt in Carb) Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Your alarm may have lost the tach signal, that was learned to it, when it was originally installed. That would cause the remote start to try starting the vehicle over and over again, until it finally stays running, because it can't read the engine speed to know it's running. If you can find the valet push button switch in your vehicle, try this; Start your car with the key and immediately after it starts, press and hold that valet push button switch until the alarm led on the dash stays lit up or the park lights flash. Then, release the valet switch, shut the car off and try remote starting it. That is the procedure to re-learn the tach signal. Hope it works for you.
My mazda b2200 starts and will stay running as long as the key is in the start position, but stops as soon as the key is turned from the start position
