Question about Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug
02 dodge ram 1500 4+4.Shaking in front end only when brakes are applied.Turned b oth front rotors,no difference.Right front caliper hung up previously,"Long time ago"Replaced R.F caliper.A surging motion can be felt when lightly applying brakes,like grabbing and letting go.Still seems like warped rotor??
Posted by william thomas on
vince
  • 1,234 Answers
Yea it does..just wondering when they got turned what was the remaining thickness if too thin they'll warp right away.
that's all I can think of off hand.
Maybe someone else has some ideas.
Good Luck
Posted on Jan 08, 2018
  • vince Jan 08, 2018
    especially so when you feel with light pressure
Bill Boyd
    Top Expert:
  • Buck Master
  • 53,816 Answers
Probably are warped
machining warped rotors only fixes the problem until they get hot again and they again warp as they are now thinner than before
the problem could be in worn suspension rubbers and ball joints
so have the front end checked out
if it turns out to be rotors , buy quality after market units and quality disc pads
have the abs system also checked out as the system indicates a braking action similar to when the abs is activated
1 Related Answer
Malcolm Grey
SOURCE: What would create a vibration in the steering
Aftermarket wheels may need hub spacers to properly centralize them .Check out EZAccessory . They tell you how to check the sizes and they sell HUB CENTRIC rings
Posted on May 04, 2012
I have a 2001 dodge ram 1500 that Upon breaking begins to vibrate and kinda bounce plus it wants to pull to he right away from the side that vibrates. Any ideas. The vibrating and shaking begins about one...
You need to have the front rotors turned or replaced. Take a set of dial calipers and measure the rotor thickness. compare that to the specs on the rotor and that will let you know if you can turn them. Put new pads on and make sure to lube the slider pins.
Sep 08, 2011 | 2006 Dodge Ram 1500
2001 dodge ram 1500 do front brake calipers interchange
Calipers come left and right. Rotors are interchangeable.
Jun 04, 2011 | Dodge Ram 1500 Cars & Trucks
Dodge 1500 ram van, 5.2 Eng. left, front brake locking on rotor. have replaced:hose or line, calibers, shoes, rotor, & bearings. No help
Possible warped rotor. Have you tested for this?
If too far gone, they sell 'em reconditioned.
If not too far gone, you can have rotor "turned" on special lathe (recut) to flat and parallel so it won't bind.
If perhaps rotor has been turned too much, caliper may not permit pistons to retract. Try installing a shim thicker than the rotor and see if it retracts.
Mar 11, 2010 | 2004 Dodge Ram 1500
Shaking brakes
Your rotors are warped. You also probably need to brake pads. Take your rotors off and inspect them for cuts and grooves. If the surface is not flat you'll need new ones. If not take them to a machine shop and have them turned. Turning your rotors will cut them down until the surface is perfectly flat and not warped. The shaking is cause when the rotors are warped and you press the brakes and the rotor applies more pressure where it's high and less where it's low, thus causes it to shake
Mar 30, 2009 | 1999 Dodge Ram
When appling brakes on a 2000 Jeep Grand Cherokee, steeing wheel
New revised calipers. and have the new rotors machined right out of the box before installing
Dec 28, 2008 | 2000 Jeep Grand Cherokee
How do I take the caliper off of my 2004 dodge ram 2500?
  1. Raise and support the front end on jackstands.
  2. Remove the wheels.
  3. Press the caliper piston back into the bore with a suitable prytool. Use a large C-clamp to drive the piston into the bore of additional force is required.
  4. Remove the caliper mounting bolts with a 3/8 in. hex wrench or socket.
  5. Loosen the bolt that secures the front brake hose fitting bolt in the caliper.
  6. Rotate the caliper rearward off the rotor and out from its mount.
    93026g05.gif Mounting bolt lubrication points—Ram Pick-Up 75mm caliper
    93026g06.gif Mounting bolt lubrication points—Ram Pick-Up 80 or 86mm caliper
  7. Remove the front brake hose fitting bolt completely, then remove the caliper with the pads installed as an assembly. Take care not to drip fluid onto the pad surfaces.
  8. Cover the open end of the front brake hose fitting to prevent dirt entry.
To install:
  1. Clean the caliper and steering knuckle sliding surfaces with a wire brush. Then, apply a coat of Mopar® multi-mileage grease or equivalent.
  2. Lubricate the caliper mounting bolts, collars, bushings and bores with Dow 111® or GE 661® silicone grease or equivalent.
  3. Install the caliper over the rotor and seat it in its original position until flush.
  4. Install the mounting bolts by hand, then tighten them to 38 ft. lbs. (51 Nm) on 2001–02 models; 24 ft. lbs. (32 Nm) on 2003–05 models.
  5. Attach the brake hose, using new washers, and torque the bolt to 20 ft. lbs. (27 Nm).
  6. Install the wheels.
  7. Lower the vehicle.
  8. Pump the brakes several times to seat the pads.
Dec 19, 2008 | 2004 Dodge Ram 2500
Front end problems
You seem to have more than one problem, first of all the balding tire you have a negative camber problem that can be adjusted by getting a wheel alignment done. The shaking problem while applying brake could mean that you have bad/warped front rotors. It can also mean bad Tie rods. Lastly it can mean that the front tires needs to be high speed balanced. Good Luck
Dec 09, 2008 | 1999 Dodge Ram 2500 4WD
Installing brake pads on 2004 ram 1500
get a c-clamp and take one of the old pads and place on the caliper piston. screw the clamp till the piston is fully seated. make sure to apply pressure evenly to not damage the seal.
do one side at a time or you may cause the other sides piston to pop out of the caliper. if both sides are already disassembled, you can take the old pads and place them in the other caliper, so the piston movement is limited.
after the piston is seated, put the new pads into the brace, it should be fairly obvious where they go. put the caliper on the bracket and install and tighten the bolts.
I would suggest buying a repair manual from an auto store, especially if you have never done a brake job before.
hope this helped.
Aug 19, 2008 | 2004 Dodge Ram 1500
Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
Top Buck Car Audio & Video Experts
Marvin
Marvin
 Mikey
Mikey
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
