altamash Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My acer MS2253 when starts, the power led going on but no display.after 15-20 seconds it will turn off.every times it happens. i checked cooler, ram,keyboard,resetting bios but same problem.when i start without any ram,there r no beep or post beep.plz, help me. i have average hardware skill.
Level 3:
  • Acer Master 19,187 Answers
  • Posted on Feb 04, 2018
Acer Master
Level 3:
Answers
19187
Questions
0
Helped
4346182
Points
82261
So are there any beep codes when it starts? What happens with all the drives and ram out?
5 Related Answers
Anonymous
  • Posted on Jul 05, 2008
SOURCE: No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Anonymous
  • Posted on Nov 17, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Hank
  • 433 Answers
  • Posted on Aug 04, 2009
SOURCE: Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
armstrng
  • 252 Answers
  • Posted on Oct 16, 2009
SOURCE: no display
Here is a link to help with your beep codes.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Hope this helps take you in the right direction.
Azrael SRL
  • 11800 Answers
  • Posted on Nov 06, 2009
SOURCE: Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
I cant make my Acer aspire 5536 work
Sounds like the hibernation and hard drive setting need looking at under the power controls, also check that a password is not required in returning from hibernation.
Acer ms2253 how can I add bluetooth device
just insert the device wait for few second the message will display ' your device is ready to use' (windows vista, 7, 8, 8.1) you have to install the software cd bundled with the device for other os (XP)
My acer aspire one only turn on the battery charge led and power button led but the screen is black .. help me please
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself that needs to be replaced.
Hope this will help...Your response is very much appreciated...
2helpful
I HAVE A NEW ACER ASPIRE ONE 521 AND ALL OF A SUDDEN IT WILL NOT START. WHEN I PRESS THE START BUTTON, NOTHING HAPPENS, WITH THE BATTERY AND WITHOUT BATTERY BUT WITH POWER PLUG. ONLY THE LED SHOWING THE...
Hi, I do understand your concern and do apologize for the inconvenience.In this regards what I would suggest you perform is please unplug all external devices from the netbook including the charger(Adapter) and the battery;then press and hold down the power button for 30 seconds without the charger or battery connected.After 30 seconds let go of the power button re-seat the battery and reconnect the charger and try powering on the netbook you should be able to get the netbook to turn on and get display. Thank you for your patience.Best wishes for your effort.
4helpful
2answers
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Acer Aspire 3050 will not boot - LEDs flashing 8 times
My Gateway did that it was due to the power adaptor being loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
2answers
Acer Aspire 5100-5022 will not power up, power supply OK
maybe your computers battery is burned or maybe it's leaking
1helpful
PD523 no picture, led blinks
Hy !
Seems to be the colorwheel. When a segment is broken, the unbalanced wheel causes vibrations. Costs approx. 100-150$. Take away back and top so you can see if wheel is not complete.
Good Luck!
Top Acer Audio Players & Recorders Experts
 Mikey
Mikey
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
