1999 Montero Sport, has factory Infinity tape deck stereo. I attempted to replace with another cd player, but get no audio. I noticed when I removed the Infinity stereo that there are 2 thick black wires (1 almost looks like a MIDI cable). Are those only for if there were a CD changer, or will I need to buy some form of adapter?
I also am mainly replacing due to no CD player and needing to call Mitsu for the stereo code.
Contact this business they are the best around. Find what fits your car Crutchfield
SOURCE: Mitsu Montero Sport '02 engine stalls but not when air cond is on.
hi there. the reason that the engine idles good when the air-con is engaged is that ussually all vehicles nowadays have a vacumm advance mechanism. this is triggered mainly by a electric solenoid valve which is also attached parallel to the source supplying power to compressor. a small vacumm hose with a diameter like a common pencil or ballpen case. its made of rubber and it runs from the alternator vacumm pump then to the solenoid valve and to the vacumm advancer unit attached to the injection pump throttle. this system raises the idle a tad higher.
if your montero runs completely normal and you experience no other problems with your engine except for your present problem, then the solution is just raising the idle a little higher. if your montero is equiped with a RPM guage on the dash, try adjusting the idle to around 800 rpms. it would be healthier for your car if the idle raises a bit when you engage the air-con because this would compensate for the added load on your engine.
hope this helps.
SOURCE: How do I reprogram a new transponder key?
you have to take it to the dealer. they have a computer that matches up your car to the key. you have to have the car and the key at the dealer at the same time.
SOURCE: need radio 'code' for 2000 montero sport with factory cd player
From Mitsubishi's site FAQ's
I need a radio code for my vehicle. How do I get this?
You will need to speak to your Dealer who can organise this on your behalf. You will be required to submit your details and proof of ownership.
By law FixYa can not provide this information.
