Panasonic SC-HT730 System Logo
Question about Panasonic SC-HT730 System
Does the Panasonic sa-ht730 system cable has a hdmi adapter
5 Related Answers
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: How to connect pc to Panasonic SC-HT730 home theater system?
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output.
Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 16, 2009
Anonymous
  • 1197 Answers
SOURCE: Im looking for the manual for the sa-ht730 please
hi
kindly download the manual from the below link
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
rating the service very helpful will be appreciated...
Posted on Aug 09, 2009
Steve
  • 3290 Answers
SOURCE: Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Posted on Mar 26, 2010
Anonymous
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
Anonymous
  • 8546 Answers
SOURCE: SA-HT730 need help with the above problem it just
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Posted on Jan 14, 2011
I have a Panasonic home theater sound system model# sa-ht730 and there is not a place for any power to go
That's because it is not a stand alone system. In fact the power goes into the subwoofer box and then a cable feeds from that to the unit into the smaller of the sockets on the lower left of the picture.
You can download the full user manual here!
http://shop.panasonic.com/support-only/SC-HT730.html
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
≥No
1helpful
3answers
hi
1helpful
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
3answers
Panasonic dvd player for subwoofer
I have a SA-HT 690 system with a bad SB-WA342 sub. I can sell you my player or buy your sub.
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
