I have changed the pressure sensor switch on my 2001 PT Cruiser (B). to find it you will have to put the car on ramps and go under the car until your under the cross member (right behind the front wheel) it will be just behind the cross member closer to the driver side wheel. remember once you remove the sensor gravity will work against you and power steering fluid will pour out of the sensor hole. and when under a car there is really no place to go and if your not careful you will have to resign yourself to being covered in fluid. good luck!
It is located in the PS high pressure hose. It is called the power steering opressure switch, it signals the computer to raise the idle speed when u turn the steering wheel at low speeds like parking..
SOURCE: Location of powertrain control module on 01 PT Cruiser?
The PCM attaches to a bracket welded on the dash panel
SOURCE: where is the crank sensor located on 2005 chrysler pt cruiser?
the crank sensor is located on back right side of engine by were the trans. bolts up.is the no start when could or hot?
SOURCE: chrysler pt cruiser fuel filter location?
Under vehicle, center, below seating area, mounted on top of fuel tank, in fuel pump module
SOURCE: where do I locate an oil sensor for 04 pt cruiser
Beneath the exhaust manifold on the backside of the engine compartment to the right and slightly above the oil filter. you must reach it from beneath the engine by putting your hand up between the CV joint and the frame. it is a pain in the rear to remove because the electrical clip is hard to separate from the sensor. on some models, a special deep socket is needed to unscrew the sensor from the engine block.
Hope this helps... Good luck!
thanks.
