Shut down the computer, disconnect ALL USB connections front and back.
SOURCE: Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
SOURCE: An old Dell Optiplex gx260 just won't turn on
Possible failures are:
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it. Happpy Holidays!
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
SOURCE: My Dell Optiplex GX1 will not boot. The Monitor shows no signal.
check whether ur ram is working or not. remove the cpu side door and remove the ram from the ram slot and clean it using a eraser gently and fix again it back and power ur pc on and check it
