Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
U2 04 Content EEPROM serial communication error Detail Error in communU2 04 Content EEPROM read/write error (Serial communication error) Detail EEPROM access process error Cause EEPROM abnormality Check and remedy Check that the EEPROM is properly set. Use SIM 16 to cancel the trouble. Replace the MCU PWB.
U2 04 Content: EEPROM read/write error (Serial communication error) Detail: EEPROM access process error Cause: EEPROM abnormality Check and remedy: Check that the EEPROM is properly set. Use SIM 16 to cancel the trouble. Replace the MCU PWB.
press 0
U2 if 04 occurs EEPROM read/write error (serial communicationerror)
if 11 occurs Counter check sum error (EEPROM)
if 12 occurs Adjustment value check sum error (EEPROM)
if 40 occurs CRUM chip communication error
1.EEPROM read/write error (serial communication error) 2.counter check sum error (EEPROM) 3.adjustment value check sum error (EEPROM) 4.CRUM chip communication error
U2
04
11
12
adjustment value check sum error(EEPROM)
40
CRUM communication error
U2
04
EPROM error
11
Main counter error
12
EPROM error
U2
04
11
12
40
CRUM communication errorYou need the service help. It is no a distans work Good luck)
Detail- Error in communication with EEPROM Cause EEPROM failure Installation of uninitialized EEPROM MCU PWB EERPOM access circuit failure
Check and remedy- Check that the EEPROM is properly set. To prevent against loss of counter/adjustment values, record the values with simulation. U2 trouble cancel with SIM 16 MCU PWB replacement
Content Counter check sum error (EEPROM) Detail Checksum error in counter data area Cause EEPROM defective Control circuit hung up due to noise Defective EEPROM access circuit on PCU PWB Check Check EEPROM for proper set-up and To prevent the erasure of counter data remedy and adjustment values, write down the counter data and adjustment values by simulation. (If there is a printer option, execute SIM23-1 and note counter data/adjustment values.) Clear U2 trouble with SIM16. Replace PCU PWB.
