Question about Sony Ericsson Audio Players & Recorders
Ear pad replacement for HPM-85
The earpads on my headphones are following apart and I would like to replace them.
5 Related Answers
Anonymous
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
Anonymous
  • 20 Answers
SOURCE: I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Posted on Mar 19, 2009
Anonymous
  • 53 Answers
SOURCE: the ear pads for the PMX 60 headphones are worn
it looks like you can buy some replacement ear pads from the following link.
http://www.thomann.de/gb/sennheiser_pmx_60_ohrpolster.htm
hope this helps. :)
Posted on May 13, 2009
Anonymous
SOURCE: how much does it cost to replace pads for my headphones
I just removed mine, soaked them in rubbing alcohol and now they are sterile and ready to use again. Oh, I forgot to mention they are now devoid of that sweat-like animal odor and garden soil - I am an avid gardener and long distance runner living in a hot, humid climate. You can also replace any damaged or worn out foam with similar products found in old cushions etc.
Hope this helps.
Shaun
Posted on Jun 16, 2009
Anonymous
SOURCE: Where can I get replacement ear pads for my
Solved my problem by finally finding the Panasonic parts dept.
Posted on Aug 02, 2009
Ha-nc100 replacement earpads cushion
CHECK YOUR LOCAL CRAIGSLIST, EBAY, OR AMAZON. THEY SELL HEADPHONES THAT EITHER ARE FOR PARTS OR HAVE BOTH CUSHIONS AND BEING IN WORKING ORDER.
I ALSO SUGGEST FOR YOU TO CHECK:
http://www.jvc.com
OR
SEARCH GOOGLE BY INSERTING THE FOLLOWING WITHIN THE SEARCH BAR: " BUY CHEAP HEADPHONE CUSHION FOR AN; HA NC100 SET OF HEADPHONES"
IN YAHOO SEARCH BAR YOU CAN TYPE:
" DOES ANYONE KNOW WHERE I CAN BY AN HEADPHONE CUSHION FOR JVC HA NC 100 HEADPHONES,
OR
DOES ANYONE GOT A SET OF JVC HA NC100 HEADPHONES FOR SALE THAT MAY BE USED FOR PARTS OR EQUIPPED WITH BOTH CUSHIONS THAT ARE IN PROPER WORKING CONDITION?"
I ALSO SUGGEST TO CHECK www.overstock.com
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
EAR CUSHION
Sony parts suppliers sell replacement ear pads. Part no 2-320-280-01 about US$16 each (not pair).
Old ear pads slip off - pull gently to stretch the part that sits in the groove of the headphones until one side slides out.
The creative sewer can remanufacture new pads from thin soft leather by following the pattern of the old ones.
No cost fix is to scrape off the remaining peeling urethane leaving the soft fabric backing. Headphones will still work but the soft earpads should absorb high frequencies.
Sep 12, 2012 | Sony MDRXD400 Professional Headphones
Tell me how to replace the cord myself, how do i get them apart? ath ad500
Most headphones have screws that hold the earpiece shells together, look under the earpads for them.
Jan 27, 2011 | Audio Technica Audio-Technica ATH-AD500...
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
Left side is quieter than right side and when pushed on makes crackling noises and sound gets louder
most likely cable is very loosely contacting the jack or earpad. Will need to be taken apart and soldered.
Nov 13, 2010 | Pioneer HDJ-1000 Professional Headphones
There's something loose in my left cup and it's really obnoxious if I move my head just a little... How do I take apart the headphones to I can fix this and still put them back together?
Most headphones open by removing the earpad and any foam. You should see access screws then. You might have to tear the foam off. You can glue it back with Bostik white glue afterwards.
Nov 04, 2010 | Sony MDR-XD200 Consumer Headphones
Koss Pro-4AA
Don't bother, Koss has a lifetime replacement policy on some headphones like the Pro-4's. All you pay is shipping. Call the repair department.
Feb 25, 2008 | Koss PRO-4AA Consumer Headphones
104 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Dai Boyce
Dai Boyce
Harrie
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
