Question about Wildgame Innovations Wild Game Innovations 12V Mono-Crystalline Solar Panel - SP-12V1
Panel will not put out more than 1.7 volts in direct sunlight
Posted by jeff on
Joseph Clark
    Scholar:
  • 95 Answers
Jeff,
It sounds like the panel's tabs were wired incorrectly or incompletely. I recommend you get a new solar panel since it seems like only one cell is outputting voltage for you now (2v cell). If possible, have the manufacturer warranty it for you since it should be putting out in excess of 14 volts in direct sunlight on a cold day.
Let me know if you have any other questions.
Thanks!
Posted on Oct 18, 2013
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
Nordic track a2050 contol console lights but controls do notvwork
If you wish to get some more details about treadmill repair then check the following link.http://electro-medical.blogspot.com/
Aug 20, 2016 | Nordic Track Exercise & Fitness
I have a white textured door and it is turning yellow, why. What can be done to fix it.
Sunlight turns the door yellow. just put it at a shadow place. not at direct sunlight.
Dec 06, 2015 | Whirlpool Refrigerators
Why isn't battery recharging in sunlight?
Failure to recharge completely could be a sign of a failing battery.
Dec 03, 2015 | Casio Mens PAG240-1CR Pathfinder Triple...
Do solar panels need direct sunlight to work?
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Nov 09, 2014 | Moultrie Feeders 12V Solar Panel
3 hours direct sunlight on 60" slim LED. Adverse impact?
The only thing I can see direct sunlight on a flat panel LED TV doing is burning the screen, making the TV hotter than usual and/or warping the frame/casing. It is not recommended according to operation manuals, and as long as you don't use harsh chemicals to clean it, keep liquids away from it, you should be fine. Just move the TV or shade it from sunlight (e.g. if the TV is near a window - pull the blinds/shades/curtains). This will make the picture easier to see during the day and also prolong the set's life.
Direct sunlight on a TV which is not turned on (or plugged into the power point) won't do much.
Dec 11, 2013 | Sony Televison & Video
I know that warmth can speed up the brewing process in beer. Should I put my bottles in the sun to help the brewing happen quicker?
NO! Don't put your beer in direct sunlight. The sun will promote the growth of bacteria and this will ruin your batch of beer. It's fine to put them somewhere warm, just not in direct sunlight. Good Luck and have patience and you will end up with a good brew.
Feb 21, 2013 | Crafts & Hobbies
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
Dead Citizen Eco-Drive
You need to expose this watch to sunlight for about 8 hours to let it recharge it's solar cell. Make sure that sunlight is shining directly on the face and not just "kind of" shining on the face. I put it in a window ledge where the sun beats down to make sure it gets the most sunlight possible.
Repeat this for a few days to make sure it's fully charged.
Jan 03, 2009 | Citizen Watches
Wildgame Innovations Wild Game Innovations 12V Mono-Crystalline Solar Panel - SP-12V1 Logo
975 people viewed this question
Top Wildgame Innovations Renewable Energy Experts
Greg Scott
Greg Scott
Lukas Alexander
Level 1 Expert
Are you a Wildgame Innovations Renewable Energy Expert? Answer questions, earn points and help others
