Question about TCL L32D20
My tcl led tv was flipped upside down. How do I rotate it back??
Posted by Limbert Jagonos on
  • Limbert Jagonos Sep 04, 2013
    my tcl led tv was flipped upside down. How do I rotate it back??
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
How do I fix an upside down SLED-32HDR TV screen
How to invert LG LED TV pictures upside down by 180 degrees
But that is for an LG TV. The same phenomena occurs regarding motherboards in some other brands. Your brand is a Sunsui.
If used with a computer:
if connected to a computer, cntrl alt + up would flip it back to normal(for some computers).. if that shortcut doesn't work you can go into control panel and flip the orientation. Or right click on an open section and select screen resolution (Win 7) The resolution will say something like Landscaped Flipped.
Here is a number to Sansui support: http://www.sansuiproducts.com/support/support.html
Aug 22, 2017 | Televison & Video
My tcl tv is showing up side down how do i fix it
This should help.
Questions Answers for TCL tv picture upside down
Mar 31, 2015 | Televison & Video
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Feb 20, 2015 | Televison & Video
How do i flip the picture display on emerson lf320em4?
When in file viewer mode you can rotate pictures, this is in the manual and may be the cause.
May 04, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
MY SCREEN DISPLAY WAS ROTATE UPSIDE DOWN
open its sevice code.go to picture menu then come on contrast & press this code 9735.tv wil go to service menu here u can do what u want
Sep 04, 2013 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
Screen display
open its factory setting & get it back.
Sep 03, 2013 | TCL 24 in. Hdtv
Can not get picture to flip
Read the setup manual more closely, the answer was very vague and a person has to pay close attention to the pictures. Found one picture that showed the menu with "flip" displayed on it.
Nov 14, 2009 | Westinghouse Electric PT-16H610S 16 in....
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
TCL L32D20 Logo
1,535 people viewed this question
Top TCL Televison & Video Experts
Lawrence Oravetz
john h
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
