Question about TCL L32D20
My screen display was rotate upside - TCL L32D20
Posted by Limbert Jagonos on
  • Limbert Jagonos Sep 03, 2013
    my tcl led tv was flipped upside down. How do I rotate it back??
  • Limbert Jagonos Sep 04, 2013
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
Screen display upside down
I think you should go to the settings and make sure rotate is not turned off. Also, try to calibrate your screen again.
Jan 20, 2014 | Nextbook Tablets & eReaders
Notebook screen is upside down
On your desktop right-click empty space and choose Graphics Options then Rotation then Built-in Display (if its there) then Rotate to Normal.
You can also try a shortcut with your keyboard Hold-down CTRL+ALT and then hit the UP arrow key to rotate the screen back to 0 Degrees.
Jan 08, 2013 | Acer Aspire One PC Notebook
Screen display is upside down
change the rotation in desktop display settings.
right click select properties>settings>advanced there should be a tab with rotation settings at the top.
May 10, 2012 | Samsung N150 Plus 101inch netbook
Why would everything on my laptop screen be upside down
Hi.
You may have accidentally hit a sequence of keys and now your Windows screen is upside down.
Press Ctrl + Alt + arrow (left, right, up or down) to rotate the screen to the correct way.
Regards.
Dec 07, 2011 | Dell Inspiron B130 Notebook
Gateway xp tablet pc screen is upside down
Hey,
Give the CTRL + ALT + *An Arrow Key*, if not try, CTRL + *An Arrow Key*, or ALT + *An Arrow Key*.
Sorry, I just forgot which one xD.
Good Luck,
Alec
Apr 06, 2009 | Gateway CX2610 Notebook
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Display is completely upside down
Try connecting it to a different computer. If it's upside-down on another computer, then the panel is probably mounted upside-down. If it can be removed from the stand, remove it and see if it can be mounted the other way.
If it's correct on another computer, then your graphics settings are incorrect. Assuming you're running Windows, go to Display Properties, Settings tab, click Advanced button, look for a tab describing your video adapter (usually ATI or NVIDIA). In the video adapter's setup there is usually a Rotation option. The rotation option may be set to 180-degrees instead of Normal or 0-degrees.
Apr 05, 2008 | Computers & Internet
Palm TX screen.
Upside down or just sideways? There is a "rotate" button on the bottom of the screen that allows you to go from landscape to portrait mode.
Mar 13, 2008 | Palm TX Handheld
TCL L32D20 Logo
61 people viewed this question
Top TCL Televison & Video Experts
Lawrence Oravetz
john h
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
