Dishwasher was fine till a cherry pit got stuck in the little red flapper valve. I disassembled and cleaned EVERYthing. found no problems besides that. Discharge path is clear to the drain. Yet still some small bits of food remain behind. Water temp OK, flow is fine.
Could that little flapper be damaged? Any other ideas?
Thanks!
SOURCE: Standing water after cleaning dishes
Clean out the air gap. Remove decorative cover by pulling up. Remove plastic dome by gripping and moving side to side while pulling it up. When you get the dome off you can see if the air gap is partially blocked.
SOURCE: Dishwasher not draining water
I had the same problem....removed hoses, checked for cloggs the hole nine yards.....Inside of the unit towards the back in the bottom is a filter cover and in the middle is a valve that you just screw out. It has a rubber stopper that overtime breaks down....I was able to pick up the part locally for about $17CDN, replaced the part and the unit drains properly now.....now I have an issue with no power
SOURCE: Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
